Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Replaced Broken Screen, Still no Video
I brought a MacBook Mid 2007 model 2.16Ghz to repair on Craigslist. It was working through a external monitor when I brought it, and will still works by that method.
So replaced the Screen and put humpty back together again. And when I went to turn it on the screen flashed grey for a minute and then still no video on the laptop screen. So what is it, a bad power inventer, did I short the Screen or simply a bad connection?
This was not a Spill laptop, maybe a fall?
Score -1
Add a comment
1 Answer
Chosen Solution
Is this a liquid spilled MacBook ?
Try to light the display back cover apple icon with a flashlight and check if you see the desktop. If so, the problem could be the inverter cable, the inverter board, or a problem with the logic board (liquid spilled damaged logic board). Your backlight lamp seems to be good since the screen flashed grey at boot up.
If you don't see a faint image of the desktop then the problem is harder to diagnostic since you don't have any video and lighting. If the MacBook still display video on the external monitor your GPU (graphic chip) on the logic board should be OK. Double check your inverter and LVDS connection to the main board. Did you replace only the LCD panel or the whole display assy ? If you only replaced the LCD panel then you're using the same cables that could be suspects. The replacement display you're using could also be faulty if it's not a known working one ??? To troubleshoot this kind of problem the tech needs to use known working parts.
Score 1
Add a comment
Add your answer
seamuskienthelegoman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,777
