Score
Crocdog
35
Asked
When screw sizes are stated in guides' does the mm(length) include top
When screw sizes are stated in the guides, does the mm(length) include screw-top cap depth? Are shank widths?
Example: LCD REPLACE:
Step 5 — Upper Case ¶
Remove the following 3 screws:
o
One 11 mm Phillips #00 in the middle of the case.
o
Two 14.5 mm Phillips #00.
Score
machead3
21.4k
Answered
Yes - see: fastener measuring the # is the driver size. That number, such as "Phillips #00" or "Torx T5" are not characterized by a linear dimension, but are for the most part arbitrary designations in the same sense as a "Size 8" shoe or dress.
If this answer was helpful please remember to return and mark it Accepted.
Score
oldturkey0
88.6k
Answered
Crocdog, that is a question, which only the person who wrote the guide, can answer. Habitually, when measuring any kind of bolt, only the length of the thread part is measured, not the bolt head. Hope this helps, good luck.
Edited by: oldturkey03 ( )
Hioldturkey, I got two answers. You say top IS included. machead3 says otherwise. Threads only. Thanx for your response. it helps. I can't figure out how to 'accept & return' on this page. crocdog
