0
Score
Avatar
Ed Heckman
Asked
Batteries not charging, Everything else works
History
Good Evening,
I have a 17" PowerBook G4 1.67 GHz machine. I have two batteries for it, one NewerTech that I purchased new about a year ago (and haven't used much), the other is the original Apple battery that only gives about an hour of life.
My problem, in a nutshell, is that neither battery charges.
When I plug in the power adapter, I get the green ring for a few seconds, then it turns amber to indicate that it's charging. But the percentage of charge shown in the menu bar doesn't go up. Neither do the indicator lights on the battery. The computer turns on and runs fine when plugged into the power adapter.
I've tried resetting the PMU, with no change in results.
This computer did charge when I got it, but somewhere along the line that stopped working. I suspect a hardware problem.
Any suggestions? If it's hardware, what part do I need to be looking at?
Thanks.
Edited by: mayer ( )
Post Answer
Score
Avatar
mayer
148.1k
Answered
PermalinkHistory
I woudl replace the battery connector: G4 Aluminum 17" Battery Connector
Product Image
Provides battery contacts — 10 available at 14.95 each.
Thanks for the suggestion. Unfortunately, replacing that part didn't fix the problem. Judging by the fact that the connector plugs into the motherboard, am I now looking at replacing the MB?
Ed Heckman,
Add Your Answer
